#293857 11/13/13 12:07 AM
stuscar Offline OP
Was any jute padding used under the rear carpet and front rubber mat of the 34 Master coach?
Stu Allen
stuscar #294030 11/14/13 06:57 PM
Not your year model but in the way of helping an un-answered post. Both my '36 car and truck had jute pad under the mat and carpet when I removed it to restore. It is not for sure that it came that way but both were from the org. owners.
terrill #294045 11/14/13 10:38 PM
The front mat had sound deadner glued to the bottom of the mat. The rear had it glued to the floor and the carpet went over it.
stuscar Offline OP
Thanks, Guys! I'll add that to my list.
Stu
stuscar #294072 11/15/13 09:51 AM
stuscar Offline OP
If you were doing a restoration today would you use the jute padding or go with the modern foil-backed insulation?
Stu
stuscar #294120 11/15/13 09:55 PM
The original was a tan colored jute or burlap type of material.
What you find today is the shredded rags (gray/blue color) or the foil backed stuff. If you can prevent slippage the foil backed will be great.
stuscar Offline OP
Thanks, Gene. I will order some of the good stuff.
Stu
