Ive been soaking cylinders with marvel mystery oil before trying anything car has sat inside since 1968 .I turned engine over with no problem today but wondering what are the next steps in finding out over all condition of engine
Do a compression test with all the plugs out. If all have good compression, you are probably good to put in some new gas and try starting it. If some are low, squirt some oil into the cylinder and try again. If they are still low, you probably have a valve problem. Pull the valve cover and crank the engine to make sure all the valves are working properly. If not, soak with some MMO and try to get them moving. If they are all moving well, you probably need to grind them.
