Posts: 5,906 Likes: 8
Posts: 5,906 Likes: 8 |
We had "strong visits" from Luxembourg and Russia.
Posts: 1,513 |
It may have been Snowden in Russia
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
Since I hunted several gremlins out of my computer I have had no problems with Chatter though I am generally online while most of the US are snoring. Tony
I just gave a reply to a stsrting problem. Couldn't find the reply on top of the list. Went to page three and there it was. Has happened before. Is it me or????
Still shaking some bugs out of the upgrade... Time posts appear to be the last things to resolve.
Keep trying, and testing... I'm working it until it's fixed.
--Bill Barker
"Edit" feature of what? where?
I see it at the bottom of all topics... Which location are you talking about?
Note: All posts made since 1 am this morning were time-stamped 8 hours too late... I've now reset the forum clock, but those postings will remain sorted at the top of ACTIVE POSTS until the "real" clock catches up and then they'll fall back into the list.
Bill Barker Previous VCCA CHAT Administrator (VCCA Member: 9802)
It is the normal Edit feature that appears at the bottom of a new post. Whenever someone makes a new post it says "Edit" at the bottom of the post for one hour. After that the post cannot be edited. Every new post that I have made less than an hour ago does not have the Edit feature. This is how a new post appears now: Reply Quote Notify Webmaster Email Post A new post should have the following at the bottom of the post for one hour: Edit Reply Quote Notify Webmaster Email Post As it stands now, a post cannot be edited at all after the post is made.
Okay... I see...
Since the posting times are messed up for any posts between 1 am and noon today -- the EDIT trigger won't work properly. The one hour edit window was "thrown off" by my changes to the master server clock.
Make a new posting and see it the EDIT shows up on it on your second visit. It should work okay as long as the clock times aren't modified any more.
Posts: 439 |
Yes,
I was just now able to log in.
Regards,
Jim M.
Posts: 439 |
No edit feature after I made the post.
Regards,
Jim M.
another test of the time It's 11:41 PM PST
Last one was off by 4 hours after setting master to Tijuana
New post at 11:46 after adding -4 offset to master clock.
11:50
And EDIT button now visible.
Okay, checking for the Edit button to see if it is visible. Will check the posting time as well. Still have my current server time set at 0.  Edit feature now visible and working. Time shows that I posted 1 minute and 33 seconds ago. VCCA logo gone again and the PM notification has returned to default. Seems like every time a change is made to CC these two features default. I have reset both features. After resetting the VCCA logo and the PM notification, both features are now working again. Looks like other members will probably have to do the same.
