Posts: 81 |
Anyone used one of those adaptor plates that lets you use an old type water pump on a 235 engine. Filling Station said it bolts right on but Chevy's of the 40's said you have to drill and tap two holes in the engine block. Whats the truth?
Posts: 1,194 |
You have to drill and tap the block.
Posts: 2,323 Likes: 6
Posts: 2,323 Likes: 6 |
Here is a link to the explanation by the original inventor. Adapter Plate Scroll down to pic 18 to start. I found his blog with the instructions. Blog with instructions
Posts: 410 |
I used the adapter when I put the '56 235 in my '42. You do have to drill and tap 2 holes. Easy install and works well. Cleon
Posts: 604 |
FWIW, Patricks <patricksantiquecars.com> (520)836-1117 has a lot of info and parts for 235's etc. Nice folks, too.
Posts: 81 |
Cleon would you give me a call at 301-937-8123 i would like to talk to you about the adapter. Thanks Alvin. After 5.00pm EST. Or email me your number and i will call you. rem6mmbr@msn.com
Posts: 1,441 |
I used it on the 57 235 that is in my 37,I pulled the front sheetmetal to drill the holes.
VCCA #45194
Posts: 318 |
I have looked at that adapter for my truck and I really can't see why a 16" electric fan above the lower water pump position on the newer 235's isn't a better choice. I see that adapter as a spot for potential leaks and I think an electric fan, over the long run is a more safe choice. The fan can be also be used much more effectively in an idling situation. If not the fan, a fan shroud will also do the job. I see that adapter as a place for potential leaks.
See Facebook Page for Joe Fuchs to see more pictures of my 1937 Chevrolet 1/2 Ton Pickup
Posts: 11,162 |
Joe, from my experience with 235 and 261 engines and aftermarket 6 and 12 volt electric radiator fans, I suspect that you are over confident about electric fans and under confident about the adapter plates for 235 and 261 post 1954 engines that allow the pre-1955 water pumps to be used on late model engines in the pre 1954 Chevrolet vehicles.
Where would be the potential leaks? The plate replaces the backing plate on the water pump.
Posts: 318 |
As far as the fan goes, I speak from experience. The one on my 37 pickup works very well. As far as leaks, I have no experience with that type of water pump so I suppose I spoke without personal experience. It seems to me that 216-235 engines have a tendency to leak - no matter what the fluid is and this seems like another spot to leak.
Posts: 11,162 |
So how long have you had the electric fan (6 volt?) on your 37 pickup? What kind of a water pump do you have? How do you drive the generator, with a fan belt?
I've had the original waterpump fan combination on my 53 (235 solid lifter truck engine) since 1991 and have never had a coolant leak.
Posts: 318 |
The electric fan has been on for probably 20 years. It is a 12 volt fan. The water pump is a rebuilt Chevrolet pump that a friend rebuilt for me. It's a good pump. The alternator is driven with a belt on a two pulley harmonic balancer. At this point, I'm almost leak free everywhere. What few I have, I know where they are, why they leak and how to fix them. I just haven't fixed the two or three I have. All of them are small oil leaks. It is a Chevy six!
