#292628 10/30/13 11:48 AM
Maxie Offline OP
1928 Capitol 1Ton Truck
Is there supposed to be a restrictor in the oil line between the oil distributor and the1/4"
oil filter? I'm using a frame can with a PIX 51006 filter.
"Preserving the old fashion way... for the fun of it."
Become a Member!
Maxie #292663 10/30/13 08:44 PM
Hi There! For a better response to your question you might want to also post your question in the 1912-1928 forum instead of here in the "New To Chat" forum.
Good luck!
Maxie #292666 10/30/13 09:21 PM
There is no oil restriction in the line.
Agrin devil
Maxie Offline OP
Thank you!
