Hi guys -
I'm having an original radio restored for my '50 Chev, which currently has the original blank factory-mounted cover plate for the radio location inside the dash. I have two questions:
1. I see that the radio rests inside a plate with holes for the dial display and the buttons where it's mounted on the dash. I doubt I can find a replacement plate - happy to hear that I'm wrong! - so I'm wondering: is there a manageable way to remove and cut the blank plate to have the radio fit in place? Would there be such a thing as an overlay to trace where the cuts would go?
2. For mounting the antenna - how should I locate the spot to drill into the fender - ex. 18" inches from X and 20 inches from spot Y...that kind of thing?
Support The VCCA!
For the finish plate you need: Contact the Chevradioman.
If you purchase a repo antenna for your car it will come with mounting instructions.
Agrin devil
Hi Ed,
Ran across my photo template for my '50 Belair antenna. Pretty sure it is in the proper location.
[Linked Image from i1264.photobucket.com]
Roger
