Hello.
I've been spending some time prepping the front end of my 40 MD Sport Sedan for a fresh engine rebuild installation and noticed the nuts that secure the tire rod ends and pitman arm retainer plate/bushings were fairly loose. I had some mechanics put in a front end kit and I'm sure they didn't use the manual I let them borrow (they never do!). The nuts have cotter pins in place, but the nut rotates easily with my fingers. I studied the service manual and didn't really find how tight they should be. I know they probably shouldn't be loose, but not too tight as well. Front end stuff is obviously serious business!
Any help you pros could give would be greatly appreciated.
Thanks!
Curt
