#291124 10/08/13 10:39 AM
olsarge Offline OP
I'm confused. I spoke to a fellow VCCA member this weekend who told me his all original '32 5-window coupe is negative ground. I thought all '32 Chevys were positive ground. Am I wrong?
See the USA in Your Chevrolet
1932 5-Window Coupe
1935 Sedan (streetrod)
1955 Apache
1955 Nomad
Two 1956 Nomads
1959 Apache
1964 Malibu SS Convertible
2012 Corvette Grand Sport
James
olsarge #291125 10/08/13 11:01 AM
I believe all Chevrolet are negative grounded.
Andys29 #291126 10/08/13 11:13 AM
The only car I know of with a positive ground are Chrysler. Chevrolet is a negative ground system.
terrill #291133 10/08/13 12:12 PM
olsarge Offline OP
I guess the real question is, my '32 was wired positive ground when I got it 3 years ago. I had it restored and the mechanic kept it positive ground. All my life I thought Chevys were all negative ground until I got my '32. Then I assumed that older Chevys must have been positive ground and changed later. I know many Fords (excuse the 4-letter word) and Chryslers were positive ground until the 1050's when they changed. My dad had a '51 Ford (excuse me again) and it was positive ground. If you jump started it from a Chevy you had to be sure to reverse the cables. Should my '32 be negative ground? It runs fine. If I change it what do I need to do? I know the generator has to be re-polarized. What else?
1932 5-Window Coupe
1955 Apache
1955 Nomad
Two 1956 Nomads
1959 Apache
James
olsarge #291142 10/08/13 04:38 PM
Hello olsarge,
In the distant past, I tried to connect the cables to positive ground on my 31 Coach. It arced so much that I stopped the attempt. Beside repolarizing the generator, I would think that the charge/discharge instrument might be reversed wired on your 32. I might be wrong on that, electricity can do some strange things, ya know?
olsarge #291166 10/08/13 10:36 PM
Yes, as mentioned above, all Chevrolets are negative ground, not positive ground. Chevrolets have been negative ground since the beginning of time.
olsarge Offline OP
That's what I had always thought. Now I know for sure. If Junkyard Dogs says so, you can take it to the bank. Thanks to all.
1932 5-Window Coupe
1955 Apache
1955 Nomad
Two 1956 Nomads
1959 Apache
James
olsarge #291227 10/09/13 08:55 PM
Let us know how you make out when you convert your car back to negative ground.
olsarge Offline OP
Finally got it done. Had the generator rebuilt repolarized negative ground and installed a NOS cut-off switch. Replaced the battery at the same time. Everything is great. Now the amp meter reads backwards but that will be an easy fix. My car must have had a Ford mechanic somewhere in its past.
1932 5-Window Coupe
1955 Apache
1955 Nomad
Two 1956 Nomads
1959 Apache
James
olsarge #324123 11/11/14 07:55 PM
I do not know about a F**D mechanic as our '32 was positive ground when we brought it home....Changed it back to negative ground with a very large ground cable and, in turn, installed a very large positive cable. Had to reverse the amp gauge too...Works great and starts quicker than my Avalanche....
olsarge #324127 11/11/14 08:17 PM
Awesome...
Glad to hear it all worked out for you !!
Funny part is My 29 is Negative Ground YET my AMMETER reads Backwards, guess they hooked it up BACKWARDS when the rewired it.
Electrical is NEXT on my List.
Yep. Just reverse the wires on the back of the ammeter and you will be fine.
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
You can also look at the 1931 Wiring Diagram in the members/technical area.
http://vcca.org/members
