Posts: 62 |
My wheelwells are rusted and need replacing. I can get the outer panels but what about the inners? The worst is the center metal below that access panel on the inside. I thought someone made this but can't find one. I can't figure out how to make this panel and was thinking that i'm not the only one working on this type of problem and would like someones ideas on how thay fixed this area.
thanks for any help
pete
1950 sport coupe
pete
Posts: 11,162 |
My idea would be to try and find a donor parts car from a dry rust free area, (Texas, New Mexico or Arizona) I had a Kansas 51 Belaire I meant to restore but after buying it I found it was a rust bucket and used it for drive-line and interior parts and crushed the rest of it, the frame was even rusted beyond any hope for restoration. Before going any further with your work be sure that the frame and components are going to be worth working on.
Posts: 1,072 |
i got a good one still attached to the fender (fender is off the car)so it will take a litle time to properly drill the spot welds out greyhound bus lines is who i use for parts like this and you will be surprised at how cheap they are or post office will do it to if can get it in a box let me know if you want it and ill get started on it right away andy
Posts: 1,072 |
pete i made a mistake i only have one for the passenger side do you still want it ansy
Posts: 21 |
Pete, I believe that the panels that you are looking for are available from a company called Autobody Specialties. I dont have any connection to this company, but I have seen some of the parts that they offer when they were displayed ae Spring Carlisle this year. They appeared in my opinion to be of high quality. Look in the Early Chevy 49-57 section for wheel houses. I hope this helps. Steve This is the web site.[url=http://www.autobodyspecialt.com]
