#290358 09/29/13 07:45 AM
Rich47 Offline OP
Does anyone know what the correct color would be for the exhaust system be on my 47 Coupe. Want to paint the exhaust pipe and muffler from front to back ands not sure of correct color. Thanks again everyone.
Rich47 #290367 09/29/13 10:48 AM
The exhaust system was not painted
So would stainless be a smart choice when replacing your exhaust system?
If you don't have intentions of having your car judged, that is the ONLY way to go. With an iron system I was replacing it every two years at the most. The stainless has been on 4 of my cars for years without any wear.
Agrin devil
Stainless is a great choice if you have your car judged or not. Just a question of cost. VCCA judging doesn't add or subtract points for stainless. Aluminized is also acceptable. Some folks just paint the pipes so they kind of look like bare metal. Hard to keep looking nice, but it can work too.
Dale Carter
VCCA #8661
1948 Fleetmaster Convertible
1948 RHD Stylemaster Sedan Delivery
1948 1-Ton Tow Truck
1967 Camaro Coupe
Rich47 Offline OP
Do you know what AACA looks for ?? I know the Vcca got me for the exhaust showing some rust as they said because the silver does not last that long? trying to get it looking right for Hershey meet. Thank You
Rich47 #290438 09/30/13 06:43 AM
I've never shown my car at an AACA meet, so I have no idea how picky they are about originality. Yes, VCCA will deduct points for rust (condition).
Dale Carter
VCCA #8661
1967 Camaro Coupe
I did pait(touch-up)my exhaust system prior to VCCA judging this summer,no deductions were received...I would think a new steel system would look close to a stainless system under the car?
Rich47 #290477 09/30/13 01:32 PM
Can't speak for individual judges but a minor amount of light rusting would probably be okay as the originals were likely a bit rusty when installed. Most people I know use coated steel which looks enough like fresh bare steel to pass. Stainless is close but generally has a shinier/glossier surface.
Rich47 Offline OP
I painted it the silver tonight with high heat paint. I want to try to find a new exhaust donut locally before I put it back in. Thanks for the info.
