Hello Jack Kennedy,
It sounds like exhaust gasses bubbling through the water that you are applying to check for leaks, is that correct, or is water leaking out of the engine around the exhaust manifold gasket area? Use dishwashing soap instead of water for checking for air/exhaust leaks. If the soap bubbles appear and fill with air/exhaust, I'd say an exhaust gasket is leaking. If the soap bubbles appear and are filling with water/antifreeze, then suspect the head to have issues. Make sure when replacing manifold gaskets, that the mating surfaces need to be clean and dry and straight. Use a framing square as a straight edge for checking straightness. If necessary, resurfacing the mating surfaces might be called for. Check with the auto parts store for the proper gasket sealer for manifolds. Permatex Copper comes to mind, but don't remember for sure. Good luck. edit: Rereading the posts, I'm not sure if you're using water internally or externally for the leak check.
