I need to know a source of supply for the pressure lever arm spring. The parts book calls it "spring, Clutch pressure lever retainer". It goes over the pin (on both endsof the pin) and under the lever. The FS has the clutch bearing plate spring but the other isn't listed. My parts book shows PN 836625. Any one have a source? All help is appreciated. I need 3 ea. (set of 3, 1 set)
The springs will fit from 1932 to 1934, so that will widen your search. The 1950 parts book has part number 473174.
JACK
Thanks for that info Jack. That will help alot (I hope). I can explore other avenues.
Got my reproduction clutch lever springs for my '32 from the Filling Station in OR (p/n AF-79).
32confederation (Canadian, eh!)
AF-79 is the spring for the throw out plate, not the lever retainer springs. FS does not carry the lever retainer springs.
JACK
