I am having some trouble with my horn button. The horn works fine but the button is not seated all the way down into the aluminum fitting that fits across the top and bottom of the steering wheel. It did fit fine and was flush with the top of the fitting but since I took it off and am trying to get it flush it is not cooperating. Can't figure out what changed. I have the nut on the top of the steering gear, the sheath appears to be where it should. If I push the sheath up all that does is push on the bottom of the aluminum and perhaps makes the ring that is seen in the sheath near the top, closer to the bottom of the steering wheel. As I said, the horn works fine I just cant get the button flush on top.
Any suggestions?
