#289108 09/12/13 07:42 PM
35pete Offline OP
Is there anyone who knows where to buy freeze plug kits for 1935 standard engine? How many are there and what size? Is it better to use brass or steel? Do I have to remove the manifolds to install?
Thanks for your replies.
35pete Offline OP
My engine block casting number is 837591-1 1935 block. It has 2 plugs that I see. 1 on L/H side and 1 on rear.
29-39 & 29-42 parts book says 1 1/4 inch. no Quantities listed. My block measures 1 1/2 inch. The 29-50 parts book says 1 1/2 inch plugs, quantity of 2, 1 on L/H side and 1 on rear of block.
So I guess the earlier books are not correct.
THANKS FOR THE REPLIES.
