langer Offline OP
Can anyone direct me to an illustrated diagram for a Carter carburetor off of a 29,
6 Cylinder?
Thanks.
Erik Langhofer
Phoenix, Az.
Hi Erik,
Here are a couple of views of the Carter Carb.
From the 1929-1941 parts manual:
http://chevy.oldcarmanualproject.com/parts/1929_41/41cp073.html
The 1929 carb is similar to the 1930. This is from the 1930 Chevrolet Owner's Manual:
http://chevy.oldcarmanualproject.com/chevyowner/30om38.htm
Happy Motoring,
Dan
Looks bout like what I have as well... Which Carter do you have 125S or 136S ??
If you need a pdf let me know, I have PDF Scans of the Carter 125S, 136S, & 150S Carbs out of my 1929-1930 Master Parts List.
Also have the Chevrolet Service News from 1929, Jan pg 8 Shows 125S, Jun p31 Shows 136S.
All of the above literature mentioned you can purchase in reprint from the Filling Station. www.fillingstation.com
langer Offline OP
Thanks for the direction. I believe I have the service bulletin for this. I will check and see. If not I will be back in touch. Thanks again for your direction.
Erik Langhofer
Phoenix, Az.
langer Offline OP
If you already have the PDF's setup, and if you don't mind, you can send them to me at:elanger52@hotmail.com
Thanks.
Erik Langhofer
Phoenix, Az.
langer Offline OP
Thanks for the tip Skip. I have the bulletins and I'll be darned if you weren't right again. Appreciate it.
Erik Langhofer
Phoenix, Az.
langer Offline OP
Thanks for being willing to send these files to me. Went home and found the bulletins. No need for you to send now. Thanks again.
Erik Langhofer
Phoenix, Az.
