#288741 09/08/13 09:02 PM
Points off or Not ??
I've had the pleasure of owning a couple of cool old Chevy's including a 41 Coupe. I have also had the pleasure of being an "assistant" judge at several VCCA events with Larry W. & Carmine P. including a national event.
During my time in VCCA I've helped judge 1940-1948 chevy's and feel comfortable doing so. But the conversation turned to "oil filters" {The type strapped to the manifolds}.
As I understand the VCCA "rules" as "The car must look like the day it rolled off the assembly line." Which means, there were no oil filters installed {?} as they were "dealer options or dealer installations." And I have NOT seen Oil filters in 1940 or 41 Accessory books.
What's the common view in judgeing Oil Filters on {1940-48} cars ? Take points off or let it go....
Thanks,
41Michael #288743 09/08/13 09:27 PM
The oil filter was not an accessory. It was considered a "part" by Chevrolet. As an example an oil filter in the 1941 parts book was in group 1.836, part # 1503611 and sold for $6.50 (plus installation).Its application is 1937-1941 however the 1937-38 unit was not the same.
Back in the pre-war years most of the filters mounted on the firewall rather than the intake manifold. The filter also must be of the AC brand....and AC had several different models for a
Chevrolet back then. If manifold mounted it is mounted in the center of the manifold with a band around it.
Say in 1950 if you purchased a new AC oil filter for a 1941 Chevrolet you got a 1950 filter which is quite different looking.
In my opinion I would not take of points if the filter is close to what I described above.
Chev Nut #288789 09/09/13 10:55 AM
As always, Thanks Gene & Chev-Chief.
Chev-Chief, I've read Pat's review several times and talked to him on the phone a couple of times. He has assembled an amazing amount of information. I have even shared copies of Pat's review with other Chevy owners, as the question about Oil Filters comes up often.
The only time I considered taking points away from a 1942 Chevy in regards to an Oil Filter was when the Oil Filter was crome plated, as were several eng. parts. So I just made note of those, the RED spark plug wires, Red Coil and Polished brass Radiator then took points off. But it was a nice car.
Enjoy,
MW
41Michael #288844 09/09/13 09:14 PM
The 48 has a special bracket which attaches it to the manifold,the 49 has the bracket welded to the canister making them very different,point deduction should be considered..Sorry guys,just my 2 cents
41Michael #288848 09/09/13 09:38 PM
While tthe list of AC filters he shows is impressive very few of the ones pictured were offered by Chevrolet. AC had a lot of different filter applications before WWII but not all would be correct.
When I called attention to him that the 1949 and up factory installed filters were painted black he had no knowledge of that.
Nice document but the images are missing. It would be great to see those.
computer
Steve Scott- VCCA Judging Committee
1985 Type 10 Cavalier Conv.
1986 Cavalier RS Conv.
https://nirvcca.wordpress.com/
Steve do you mean this,I can see them?
http://ddautoparts.home.mindspring.com/oilfilter.htm
Chef, yes there we go. Nice pics. Thanks for sharing.
kewl
