#288290 09/03/13 01:53 PM
Lemont Offline OP
I have two (one on each side) fitting that is similar to a zirk fitting. Each are located in the middle of the horseshoe bolt that attaches the springs to the axle housing on the rear of my 32. This fitting is straight and slightly wider than a zirk fitting with a ball on the flat end of the fitting. They also have two small pins (on on each side of the fitting. What is it? Does it take grease or rear end oil?
Where can I find the adaptor for my grease gun? Thank You
Paul Orednick
Lemont #288292 09/03/13 02:12 PM
Alemite Pin Fittings
looks like this: Alemite Pin Fittings
As for an adapter, not sure ,but Alemite makes the guns, fittings, etc... Alemite Pin Type
You can Usually get a good Alemite Gun from that era on Ebay pretty cheap, I have on one hand myself.
Looks like Alemite also makes some couplers Alemite Couplers Go from Hydraulic to Pin type....
Looks like you can get these from McMaster Carr, Maybe Fastenal, Grainger ??
Lemont #288294 09/03/13 02:25 PM
Paul,
Each lubrication point on your '32 chassis should have a pin type Alemite fitting. They are intended to use heavy oil. Alemite still has some of those fittings available. They are still used on industrial machinery to oil bushings/bearings.
Lemont #288299 09/03/13 02:42 PM
You can get an Alemite adapter for your grease gun from Gary Wallace. http://www.20schevyparts.com/
