A lot of us in the west have used a car dolly since many of us could not afford trailers.
Be aware that front wheel drive cars with radial tires are the intended use of car dollys, and that is not what you are doing when towing a Chevrolet of the 50s or earlier.
There are three main issues to be aware of:
1) tires. a) A dolly usually comes with radial tires. If you tow a car with bias ply tires you can have control problems due to how the different types of tires track the road. b) The dolly tires must be able to handle the weight of the dolly and the front of the car. A dolly weights about 1,000 pounds. a 1950 Chevrolet sedan might weigh 3,500 pounds ready to drive. Your dolly tires must have a weight rating higher than 1,375 pounds (3500/2 + 1000)/2 = 1375. Ask me how I know about these issues...
2) Transmission and Drive line lubrication. In normal operation a 40s - 50s Chevrolet will be, on average, going both uphill an down hill an equal amount. The amount of time going exclusively up or down will probably not be more than 10 miles. When being towed on a dolly your car will be at a constant uphill angle for hundreds or thousands of miles. From my experience and those of others, 500 miles each way to a meet is certainly not a problem, assuming you made sure the transmission and rear end lubricant levels were topped off prior to the trip. Note that your odometer will be recording mileage, and your speedometer will be working, not that you can see it, while you are towing on a dolly. For trips longer than 500 miles I would recommend either renting an open trailer or do as I did going to Flint, MI from Denver, CO and disconnect the u joint after loading the car on the dolly, and after getting to your destination, reconnect it and add lubricant. That is a lot of messy, hot work, done 4 times on the trip. If I were doing a trip like that again, I would certainly spend the $400 my local independent trailer dealer wanted for me to rent an open trailer for 14 days.
Another possible issue is that, due to jostling during towing, your transmission might slip into gear and be turning the engine over with raw gas going into the cylinders. To prevent that I made up a clamp of plywood, carriage bolts and wing nuts to lock the transmission shift arms on the steering column so the transmission could not go into gear.
3) Locking the steering mechanism. You have to do this. The cheap easy way is to wrap the driver's seat belt through the steering wheel and tighten it. A better way is to cut some plywood and use carriage bolts and wing nuts to clamp the steering wheel against the front seat cushions to prevent rotation.
In summary, a car dolly is an inexpensive but viable way to get a collector car to/from a meet or tour, but you have to be careful.
