#286571 08/14/13 04:37 PM
stuscar Offline OP
I'm ready to install my vacuum wiper motor but need help.
Is there a seal or washer under the chrome nut that secures the wiper motor where it exits the body?
What is the function of the beveled cast pieces on the shaft between the housing and the threads on the shaft?
Any advice would be greatly appreciated.
Stu
I think that beveled piece goes against the w/s header on the outside as it's not flat
...Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
There is a rubber washer between the chrome piece and body on a 36.
Richard
I believe Joe is correct. That is how I installed mine.
Here's a couple of shots.
Stuscar, there is a rubber washer that goes between the car body and the chrome spacer, then an internal-tooth shakeproof lock washer, and finally the nut.
Bill Masters
So I'm missing a few parts here. Is that just a plain washer?
Pat, here is a link to the 1929-41 parts book that shows a picture of the shakeproof washer (group number 8.932). The internal tooth washer is the picture second from the left.
http://chevy.oldcarmanualproject.com/parts/1929_41/41cp222.html
This is a better picture. I think it is 5/16 inch, but I can't remember.
http://www.fastenersuperstore.com/w...washers?gclid=CMn15vCs_rgCFUyi4AodEV4AgA
Bill Masters
stuscar Offline OP
Thanks, Guys! I have all the pieces but couldn't remember how they were assembled.
Stu
Is the rubber washer just a plain washer?
[Linked Image from i645.photobucket.com] These are for a 36 and up.
Pat, I used a flat piece of rubber about 1/32" or more. First, I punched a hole in it to fit around the wiper motor's shaft, then slid the spacer on, then ran the nut down finger-tight, traced around the spacer with a ballpoint pen and cut it out.
Bill Masters
Thanks Bill. I suppose there is no chance of the motor falling back in with the windshield header trim in place.
I don't think it will fall. If needed, you should be able to hold it against the body from inside the car with one hand applying pressure against the wiper motor controls while threading the nut onto the shaft with your other hand.
Bill Masters
