#285485 08/03/13 07:52 PM
can anyone tell me whatheadlight and brake and taillights bulb to order from fs.have halogen bulb now one burt out.they gave more light but my generator could keep up even with it set up.do not plan on doing night driving no more then 20 miles away then only if I get caught ouy. thanks.
smitty
Look for the part suppliers in the G & D or most all of the ones on the net have them.
If you're still using the prefocus base bulbs it's likely the 2320 or 2330. The 2330 is a slightly higher cp bulb. If you can't find any I have a few extra. As for the tail light I'm not familiar with the '36 tail light. Is it a double bulb housing that uses BA15 (15mm bayonet) base bulbs? If so the #81 bulb works well for the tail light. You should be able to get one at your local parts store.
Edit: Here are some 2330 about as cheap as you're going to find them.
