Mine is dripping at the large nut on the tube behind the tranny. Is this an easy fix?? ....I looked for the cork seal and saw one in a complete gasket package for the ball-universal joint area, but none alone.....also just behind the oil fill hole on the side of the tranny...maybe 1 1/2 inches behind....there is a small round 1/4 inch in diameter looking head of a metal pin flush with the side of the tranny housing. It`s weeping oil . What is it and is that something fixable without pulling the tranny? Thanks for input ~David
David Martin-Hendersonville NC, Pine Island Fl....... 1940 Chevy SDSS,
You can try to tighten the packing nut that is at the rear end of the ball tube. The original packing inside the tube was rubberized felt packing with a large squish washer on each side. This worked resonably well. New kits come with a hard cork seal and they dod not squish as easily. May require several tightenings.
Pin leaking oil? You could have a 1941 transmission case that had a bolt in that location and some one blocked it off with a pin of some type. The 1941-1948 had a bolt in that location that held the vacuum shift canister in place.
