#283907 07/16/13 09:02 AM
RonH Offline OP
I'm hoping to find a way to know what color my car was originally painted. Unfortunately, the tag on the firewall is missing.
Are there any other factory tags I should look for that would tell me that info?
Does a cross reference exist that links the engine/frame number back to the car numbers/factory info?
1936 Chevy Standard Coach
1936 Chevy Standard Town Car (Late model)
Basketcase
RonH #283923 07/16/13 11:16 AM
Your best hope is to find a small amount of paint that remains in a hidden or covered spot. Carefully removing paint layers until you get to the layer just above the primer on bare metal can be the original color if the car was not completely stripped. If stripped then look for a place that might not have been stripped.
RonH #283937 07/16/13 04:09 PM
A couple of good places to look is up under the Body where the Rear Fenders fit, inside the Trunk Lid or under the Body below where the Doors are.
Jon T.
RonH #284333 07/21/13 05:56 PM
Many times you can look on top of the passenger door. With the door open; stand on running board and look down.
RonH Offline OP
I polished up some of the paint today and it's black. I think I go back with that or maybe admiral blue.
Basketcase
