Posts: 151 |
Here is the next question from the '490 novice: What is the best way to change a rear tire on the '490? I can not get my 2 ton trolley jack under the rear axle without bumping into the "rod" running underneath the rear axle. I'm sure there is a simple explanation, but I thought I would ask before messing something up. Thanks in advance for any information you can provide! - The Ol Coach
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
You should be able to place the jack under the chassis rail where the springs are mounted to the frame. I am pretty sure there is a picture in the 1919-1922 repair manual with the front jacked up at that point , removing the front wheel,
JACK
Posts: 151 |
Thanks so much, Jack! I'll check it out. - The Ol' Coach
Posts: 173 |
The Ol' Coach,
Something I also did was I cut a piece of 2x4 and added a couple of pieces of wood to the edges of the 2x4 and made a bridge (if you will) that I place in between the axle and the rod so the hydraulic jack lifts on the wooden edge pieces that are bridged over the rod and lifts the axle that way. I do this when I am only picking up one side at a time. I hope you are able to picture what I am talking about. It works very nicely.
Cheers, Gary
Just checked the repair manual. Page 63 shows a jack under the frame rail a few inches behind front springs, so a few inches in front of the rear springs will be sweet. Less weight in the rear , compared to the front with the engine weight.
JACK
Posts: 151 |
Thanks very much for the help, Gary and Jack! I'll see what I can do. - The Ol' Coach
Posts: 151 |
Thanks again guys! I got it done by taking a piece of 4x4 and standing it up between the frame rail and the jack - worked fine. The Ol' Coach
