#282005 06/26/13 12:26 AM
RonH Offline OP
Recently bought a 36 Standard and will want to rebuild the carter carb.
Any suggestions of the best rebuild kit? I understand there are better and worse kits.
Is this a straightforward process? I've never rebuilt a carb. but I'm not scared of things I've never done before. If I was I wouldn't have bought this car.
1936 Chevy Standard Town Car (Late model)
Basketcase
Hi RonH
We stock carb tune up kits for the 32-49 Carter W1 carbs and also have new floats in stock. The carb on your 36 Standard may have been replaced at one time so would need the carb number or need to know if the accelerator pump has a round brass shaft with a bolt on piston or a flat steel shaft with swedged on piston. Take off the tin cover which is retained by one bolt and operate the carb. The shaft that goes down into the float bowl cover is the accelerator pump. The accelerator pump concerning the kits is the main differences. The kits that I stock are made by a reputable manufacturer here in the USA. The float needle in these kits is an aluminum needle with a flat flouroelastomer tip in the end with a concave seat machined inside the seat. These kit are made to handle todays fuels.
To check out these kits, please click on this link
http://marxparts.com/repro%20chevy_fuel.htm or go to our website www.marxparts.com
Regards Bob@marxparts
RonH Offline OP
Thanks for the info. I'll take a look.
How hard is the rebuild?
Pretty straightforward??
Basketcase
Its not bad, lots of little parts but if you stay organized its pretty easy.
RIP Trololo Man 1935-2012
