Posts: 861 |
What size bolts fit into the steering wheel that would attach to the puller?
Thanks in advance.
Bill
Posts: 977 Likes: 7
Posts: 977 Likes: 7 |
Bill, I had to tap the existing holes in the hub of the steering wheel where the two legs of the horn button enter. I used a 10-32 tap, then I used long screws and a home-made puller.
Bill Masters
Posts: 861 |
I tried using a 10-32 bolt. It appears to be about the right diameter but the wrong thread. I was thinking I might have to tap it. Thanks.
Bill
Posts: 5 |
The screws to attach the puller to the steering wheel are typically 5/16"18 or M8-1.25, with some 1/4"-20 or M6-1.0 in use as well.
Posts: 19,758 Likes: 63
Posts: 19,758 Likes: 63 |
rbl2, The holes are not tapped. You will have to cut threads in the holes so you can use the 10-32 machine screws. Will probably also need one or more washers on the screw head depending on the puller (so the screws done pull through the puller arms).
Posts: 861 |
Everything has been removed, rebuilt, re-installed and adjusted. I have yet to drive it but I already know there are adjustment problems. I'll find out tomorrow.
Bill
