Posts: 434 Likes: 1
Posts: 434 Likes: 1 |
The engine that I'm currently working on has the casting number 838710 with a 15 under that, and on the ID plate 1440841, all of which indicates that it is a 1938, if I'm not mistaken. I have a couple questions I hope you can help me with:
1. Is there any way to ascertain whether it came from a car or a truck?
2. The water pump on the engine has the number 598309 cast into it. In my big parts book (which covers only up to 1942), it says that the original water pump number for this year was 603148 and that was superseded by 598308--I'm wondering where the 309 came from--is that a later replacement number?
3. I have two NOS water pumps that I've collected over the years, neither one of which will fit this 38 engine. The boxes both say they're for a Chevy 216/235, but I can't find their part numbers in my book--must be from a later engine. The part numbers are: 3736567 with 12GM underneath; and 3757232 with GM 2. Can someone identify these 2 water pumps for me?
Thanks very much!
Jim
Posts: 7,472 Likes: 26
Posts: 7,472 Likes: 26 |
I have a 29-38 parts book that list the pump assy. numbers and the part numbers for all parts. It list the 1937 pump assy. as 838464(replaced by 603148) then replaced by 598308 assy. The 598309 is the cast number for the body of the 598308 water pump. Often times GM casting numbers are a digit or two different than the part number as they may use the same casting for various assemblies which use different attaching parts such as the pulleys or shafts. I also have a 29-55 book but had no luck with the other numbers you posted.
Posts: 434 Likes: 1
Steve,
Thanks. Yes, these are casting numbers that I'm quoting, so that explains why they don't exist in the parts book. Apparently, there is no specific way to identify these from the casting numbers.
Thanks again,
Jim
Posts: 6,689 Likes: 21
Posts: 6,689 Likes: 21 |
1929-50 book reads: 1937-38 All (use offset fan) (casting No. 598309 pulley stamped 838764) Part no. 598308 1939-40 All (casting No. 598309 pulley stamped 838905) Part no. 838903 Note: Repair parts for original 1937 water pump (part 838464 and original 1938 water pump (part 603146) may be identified by their respective part numbers. ... Fan blade 838933 must be installed with 5983 1937 series GA and fan blade 838936 must be installed ith 59308 on 1937 series GB, GC, GD GE, S. I don't know if this helps or not. Charlie
Posts: 434 Likes: 1
Thanks Charlie. That does help because it explains the 598309 casting number for those years. Much appreciated.
Jim
Posts: 2 |
I too have been researching water pump casting numbers, and I found this page: water pump it says your 3757232 pump is a 59-62 unit. If anyone can verify this for me, Id appreciate it, since Im looking for a correct 1959 water pump for my 235.
