Posts: 191 |
I am seeking best method of valve adjustment on a 1940 - 216. The shop manual says to adjust to spec's - intake .006, exhaust .013 after engine temp stabilizes or (other way) adjust valve rocker arm open until it starts clicking then tighten till clicking stops and lock off, repeat on all valves. Seeking your opinion on best method. Thanks,
six volts forever
The valves are adjusted with a feeler gauge,engine at full operating temperature and running at idle speed....as per shop manual.Don't understand the "other way" and it is not shown in the CHEVROLET shop manual????
Posts: 119 |
Chevgene is right. You should do it the shop manual way. Run the engine for at least 30 minutes. Idle the engine as slow as possible, if you've not done this before you may wish for 3 hands but you'll get through it.
Chevy lover
Use a boxed end wrench for the lock nut-stubby screwdriver for the adjusting screw...when adjusted correctly the feeler gauge should slide thru between the valve stem tip and rocker arm with a little resistance.If it hangs up its too tight-
Posts: 6,149 Likes: 42
Posts: 6,149 Likes: 42 |
I generally adjust valve clearance with engine fully warmed but not running, makes it much easier to get an even setting. Each to their own of course. Tony
