I wanted to know the best way to keep the 3 speed transmission from leaking. I had mine rebuilt but it is leaking everywhere. It shifts fine but it leaks like crazy any help would be great. Thanks in advance
1947 Chevrolet Fleetline Aerosedan Country Club
1948 Chevrolet Fleetline Aerosedan
1948 Chevrolet 1/2 ton truck
A rebuilt transmission should not leak! To rebuild means to replace all the seals and gaskets along with all the needed mechanical parts. Are there cracks in the housing? Whoever rebuilt it should fix it for free.
Richard
Waverly, IA
There is a shaft that is exposed to the outside (back) of the transmission. If the shaft is worn or the bore is sloppy,it will leak. I cleaned mine with paint thinner and covered it with silicone.
