#279344 05/28/13 08:56 AM
I have my timing set properly but I have a pinging problem above 45 mph. In order to correct it I have to pull the retard a little to stop the ping but the power drops.
Do I need a cooler spark plug? Currently using a Champion D-16 spark plug.
What is your timing set at and what is the gap on your D-16 spark plugs?
It was set according to the instructions on the web site.
The information on the web site (.040" spark plug gap and 18 degrees timing) only applies to the AC-C86 or the AC-C-87 spark plugs, which are the correct modern replacement plugs for your engine. With the D-16 plugs you might want to set the gap as recommended for that particular plug and set the timing back to the original 12 degrees.
