ron1967 Offline OP
does any member have some old parts catalogs that show some of the first starters and generators from the 20's (in particular Autolite, Delco Remy, etc).
cant find any on line, repair shops or even junk yards that show the parts of the 20's.
I'ed be interested in copies if someone has some and would pay for the printing costs.
would be great if it listed the Chevy year and model it was used on, Gen & Starter parts # breakdown and even some exploded views.
thanks ron
Try here
http://chevy.oldcarmanualproject.com/parts/1916_28/index.htm
runs from 1916 to 1928
Hope this helps. Neil
This link may also help, as it includes some diagrams and detail specifications:
http://chevy.oldcarmanualproject.com/chevyresto/28index.htm
Chuck
ron1967 Offline OP
I looked there but it doesn't give the Mfg or model for the starter or the Gen, it does give the Dist though
Ron , have sent you an email.
JACK
I looked through my 28 parts manual which covers all 4 cylinder models, but all they give are the individual parts for them, but nowhere does it list the entire generator or starter model #. My 28 Coupe has a 710-D STARTER. I believe there were also an entire 710 series with letters like 710C, 710B, etc. but don't remember exactly which goes with what without doing some research. The repair manual does not mention model numbers for either of them. I checked my 28 coupe GENERATOR and it has model 943B. The 20s is a broad range of years. The 1940 Parts manual just refer to 4 Cylinder models, which I can only conclude is for any/all 4 cylinder models prior to going to 6 cylinders in 1929.
Hope this helps.
RON1967;
I have a lot of old parts books that list parts for individual models and years. Almost all Auto-lite starters and generators had been replaced by Remy parts.
Generators Remy P/N 811703 Model 950A Series B & D
P/N 812585 Model 950B F,H,K,M,R
Starters Remy P/N 813397 Model 710C Series K,R,V (X?)
P/N 820233 Model 710D 1928 parts book
shows this model
replaces all 710C's
I have some more info on old Auto-lites but they get complex and too much to go into here. If you really need the info I'll take some time out and get it to you. I hope this helps.
Steve
ron1967 Offline OP
I have the 4 cyl chevy parts book, I purchased the Delco Remy parts catalog but none show the early Auto Lite numbers or pictures
the ones I found is an Auto Lite "MF"
thanks for your time
ron rjmc1967@yahoo.com
An Auto lite "MF" starter is a 1916 to 1922 490 Chevrolet starter.
JACK
