Posts: 41 |
I own a 1930 Chevrolet Sport Roadster and would like to clarify the recommended Oil Grade that should be used in my 3 Speed Manual Transmission & Differential .
Every time i raise this subject with other 1929 - 1932 Chevrolet Owners i get conflicting advice .
Penrite Oils suggest that i use TRANSOIL 140 (Note : Penrite Oils equivalent of 600w is TRANSOIL 250 ( Steam Oil ) but this to heavy.)
Please advise , thank you for your help.
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
JACK
Posts: 1,966 |
Not sure why anyone would depart from the manufacturer's recommended oil, i.e. 600W or modern equivalent. That's what I have put in my tranny, U-Joint case, rear-end and steering box, and everything works just fine. Don't plan to drive in cold weather, so thinning for winter driving is not an issue. As they used to say, if all else fails, read the manual!
600W is the correct oil to use in your 1930 transmission and rear end. You can get the correct 600W oil from the Filling Station. www.fillingstation.comBy the way, 600W is equivalent to the modern day 160W.
Posts: 331 Likes: 4
Posts: 331 Likes: 4 |
I believe the FS also sells reproduction owner and service manuals for that vehicle at a reasonable cost. They have been most helpful in my quest to learn the basics from GM at that time! Best of luck!
Posts: 41 |
Gentlemen ,
Thanks for the Clarification on the 600W Oil and Jack for the 600W Information Sheet .
" When in doubt ask the people that know " Thanks again.
Regards,
Posts: 860 |
600W is the correct oil to use in your 1930 transmission and rear end. You can get the correct 600W oil from the Filling Station. www.fillingstation.comBy the way, 600W is equivalent to the modern day 160W. SPO-288 Oil SPO-288 Oil always wholesale at www.InStockSupplies.com. ISO viscosity grade 680|AGMA No. 8|SAE Gear Oil No. 250|Viscosity index 98|Specifically designed for industrial applications such as gear cases, bearings, chains, machine ways, and general oiling, and also for bevel, helical, and spur gears I have been running LUBRICATE oil in my 31 transmission and differential for several years and have virtually stopped all leaks. It might be noted that it is not recommended for use in tranny`s with free-wheeling and synchromesh. hoppy
"Four-Doors-Forever"
It might be noted that it is not recommended for use in tranny`s with free-wheeling and synchromesh. According to the 1932 Chevrolet owner's manual, 160W (which has the same viscosity rating as 600W) should be used in the synchromesh transmission and free-wheeling.
