#278534 05/18/13 04:21 PM
p.k. Offline OP
Looking to find a way to remove the column shift linkage from the steering column. Nothing in the book about what has to be taken apart. I have removed the shift rod, but how does the gear shift rod come through from the engine compartment ?
Any help would be appreciated....... thanku
p.k.
1956 BEL AIR 2 DOOR HARDTOP
p.k. #278546 05/18/13 07:12 PM
You might consider asking on <chevytalk.org> or <H.A.M.B.>.
Gaither #278555 05/18/13 09:29 PM
I would say that the clamps holding shaft to column, both under hood and under steering wheel, must be removed and the the steering wheel has to be removed and shaft pulled up into the passenger compartment.
These pics from the '39 shop manual might help. You could look in the shop manual for more pages on assembling the linkage.
[Linked Image from i27.photobucket.com]
p.k. Offline OP
thanku Hayree, I just got ahead of myself looking through the manuel. patriot
p.k.
