#278132 05/13/13 05:33 PM
Is the travel of the distributor vacuum advance on a 216 the same as a 235 ? Or may not even fit a 235. Still trying to get my engine to purr like it should ! Thanks.
easymoney
As an example the same vac. advance was used from 1941-1951, 235 and 216. The models up from there had some clearance problems and amount of advance differences. As an example the 1951 unit advanced the timing up to 20 degrees. The 1962 unit advanced it less than 1/2 of that amount.
How would you describe your running problems??????
Chev Nut #278179 05/14/13 06:11 AM
It starts good, idles good. At fast idle to about 40 mph runs rough. step down on the gas and wants to really go for a moment. After 60 years who knows what parts were used. Thanks.
easymoney
Chev Nut #278385 05/16/13 04:25 PM
I changed the vacuum advance, I think the spare one I had both ended up to have the same travel ! The spark looked weak so I put on a new coil , lots of spark now . Seems to start off good ,then when up to 25 or so it breaks up. I think that the power valve is working ok. All passage ways are clean and clear. What should the main fuel jet be or where can I find that info ? Could the lower octane these days require a larger jet ? A while ago I put a 55 235 in a 51 panel with a split manifold, had a time getting that to run right. Ended up enlarging the jet and that fixed it. Thanks I know the answer if I could just think of it.
easymoney
I have the stock jets in all my cars and they have been running fine for over 20 years on the ethanol gas.
Chev Nut #278431 05/17/13 12:08 AM
First, I know nothing! However, it has been my experience (at the instruction of others) anytime I opened up the exhaust flow on an engine, I had to increast the carb's jet/s size. Ain't got nuthin to do with this crappy ethanol fuel. They just flow more air and thus need a bit more fuel (and they do perform better in most cases).
Have you increased the exhaust flow on the Chevy in question?
Gaither #278439 05/17/13 01:13 AM
I have dual exhaust and run stock carburator jets...The only time I have really had to mess with reverse flow main jets, is with 2 stroke motors...You might have dry pump leather...
When was the last time you changed your plug wires...?
kevin47 #278477 05/17/13 05:21 PM
I have two vacuum advance parts. There are numbers on the mounting plate, 140 and 143. Do these # mean anything ? Thanks.
easymoney
From what I see the 140 is for a 1952 passenger car and a 1958-1962 car.
The 143 would be for a 1940-1951 car.
The above would also be for some trucks.
The main differences is the location of the motor mounts required a different location for the actual vacuum control.
Chev Nut #278493 05/17/13 09:36 PM
Just making sure I have the right one (140) on my engine and I do ! I tried the 143 and seam to have the same travel no difference in engine running. Would the 143 be for a 216 ? The 143 is angled out to miss the mount. Still looking for the problem ! Thanks.
easymoney
They all have the same movement. The 143 would be afor a 1952 216 car as well as a 235 car.
Not certain what issue you are attempting to correct, I understand you are focused on timing advance, BUT have you checked the centrifugal weights? Is the movement free and easy? Are the springs intact and operating properly?
Had the distributor all apart checking the springs and weights only found crud . Cleaned up and put back together. Put back in engine for the 3rd time ! Would hardly run, set the timing , not any better . I must have stumbled on to something! Under the cap the rotor looked lose on the shaft so I looked thru my spare parts and found a new one, only to find that the rotor wasn't even the right part. Must have been around 1/8 to 3/16 short from the cap.Thats why it would start but not run under load! The right part is in it now and it runs GREAT. Thanks everyone for all the advice.
easymoney
Always good when the final step brings success. dance
Glad to hear you solved your problem. You might want to check your distributor number to see if it is a 216 distributor. I had the same situation after attempting a tune up on my 51 216 only to finally discover someone had installed a 53 distributor that used the longer rotor.
m006840 #278639 05/20/13 01:31 AM
I'd think one would pay more attention to the rotor length...I recall having a motor that wouldn't start simply because one of the "springs" had broke...Wouldn't think that would "kill the deal", but it did...Took awhile to figure it out... laugh
kevin47 #278704 05/20/13 08:33 PM
All it takes is time !
easymoney
