Posts: 1,125 |
While trying to correct my leaks I noticed that the regulator for my passenger side vent window has a lot of play in it. Is this repairable? Does someone make a rebuild kit? Does someone have a good used one? Thanks, Sid
There is an adjustment for that. See shop or body manual.
Posts: 1,125 |
Thanks Chev Nut. I'll check it out. Sid
Posts: 1,125 |
I was able to adjust the regulator and eliminate the play. It wasn't easy getting the wrench through the small hole, but it worked. Thanks again Chev Nut. Sid
