#277784 05/09/13 06:53 PM
ollieo Offline OP
First post on here .. hi every one..
has anyone got a link to the aftermarket turn assembly that attaches to the steering column.
My local authority deems that the clean looks of the 38 coupe would be better served with more lights than it comes with as factory standard
Seems to be a fairly common item . wawuzit's coupe from earlier this year had it fitted (chrome) and have seen on lots of other cars as well
cheers
Ollie.
Hey Ollie,
First, welcome to Chevy Chatter and hopefully to VCCA in the future. This is the right place to get answers to your Chevy questions.
If you need a turn signal unit, just click on the Filling Station advertisement on this page and chase it down from there. They have them and a gazillion other items for our Chevys.
Or click below....
www.fillingstation.com
or
www.chevsofthe40s.com
Good Luck and come back often.
ken48
VCCA 42589
ollieo Offline OP
Thanks gentlemen .
you guys are all over it . well done.
have been through Fillingstation catalog (alot ) My favorite book . Can't find in there but the ebay links will do just fine.
Just found in chevs of the 40's .. new i'd seen em somewhere.
thanks again
Ollie
Jim Carter Truck Parts 1.800.862.1913 has out of sight, behind the dash, no clamp on steering column. Only a toggle switch lever is seen below the dash. Beep tone, signal on. Keeps a more original dash appearance. Maybe what you are looking for?
So Jim do you have any original turn signal parts?I need an original 48 Guide turn signal switch
ollieo Offline OP
http://www.oldchevytrucks.com/cart/product.asp?prodid=EL13112&i=|turn%20signal||||
Small toggle switch .. good idea .. think I may manage that out of the local auto elec shop...thanks
Ollie
Hi ollieo I would use a new flasher unit capable of 80 flashes per minute, otherwise the cellphone generation driving behind you doesnt have the time between sms's to wait for your indicators to flash.Get a 7 wire turn signal unit so you can wire your existing stop lights for turn signals, then you only have to change the park lamp holder in front for a double contact lamp holder.
ollieo Offline OP
Only one stop light . master coupe.
For local regulations I will need to have turn signals each side. So as not to change the car I will put removable units (small) attached to the bumper bar (stealth) , also need reflectors each side.Local parts store has LED brake/park/reflector indicator units i can wire in with connectors so I can strip when I get to club events.I understand that an LED flasher unit is needed.
Probably not a bad idea with the number of psychotic,blind,irrational uncoordinated road users I encounter daily.don't get me started !!
ollie
Ollie, I'm no "electroqutionist" but from experience with LEDs on motorcycles, you can likely get by with using an Electronic Flasher (instead of the old type Flasher). It will flash all incandescent bulbs, a mix of incandescent & LED bulbs or all LED bulbs.
Good luck - -
