#277589 05/07/13 06:59 PM
1922c Offline OP
I bought a headliner on line from Jim Carter. when I received it the bill stated customer must cut and fit..No headliner in the truck to make a pattern from..Any suggestions??? If you look at the online add you think you are buying a headliner
How about making a pettern with some other material first?
When I made my headliner out of the standard brown interior boad that can be bought at any upholstey supply shop, I first bought six or so pieces of poster board at the hobby store and I layed out my headliner divided into six sections. I cut each of the six pieces to fit in each of the six areas of the underside of the roof so when taped together they would cover and be the entire area of the headliner. I adjusted, cut and snipped until I had a good fit. I then layed the pieces on the headliner board and cut it to the pattern I had made. I over cut slightly so I would have a little wiggle room. When I installed it, it fit almost perfectly. I had to cut and snip a few spots, but basically I got it. That was back in the 90's and it is still right where I put it!
Tech Advisor for 1937-38 Chevrolet Trucks
1922c Offline OP
Thanks for the info. I made a pattern, but not sure about the curve above the doors..The center spacer has a much sharper bend than I can get with the materal I'm using, when I try to fit the curve it wants to buckel.. Jim Carter apologized for the way the ad was worded and is changing it. Thanks Joe
