#276433 04/25/13 06:18 PM
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
Working on my 1936. I have replaced all wheel cylinders. Rebuilt the Master cylinder. And installed all new brake lines.
When I try to drive the car in my driveway, the right front wheel locks up and leaves a long patch of rubber. And it only does this going forward. In reverse all of the brakes seem to engage fairly evenly.
I took the front hub off yesterday.
  • The return spring is good.
  • The brakes are like new - but when I ran my fingernail across them I got a small amount of black goo on them.
  • I cleaned the shoes with brake cleaner.
  • I cleaned the drum although it was very bright and clean.
  • Then sanded the shoes with 200 grit - and cleaned them with brake cleaner again.
  • Last step was to back off the adjustments about 4 clicks.
When I installed the brake cylinders and lines, naturally I bled them all.
What are the possible causes?
--- Oily shoes?
--- Air in the line?
--- Adjustment still bad?
Thanks for any ideas.
It sounds to me like the wheel cylinder is hanging up. When you push the peddle there is enough pressure to push it out but it is tight enough to not return.
With drum off,push the shoes back and forth to see if they move free.
I would also check the lh side. Possibly something on that side is keeping it from getting equal braking force-such as an internally collapsed hose or air in the line.
replace the oil socked shoes as they cannot be cleaned successfully.
Al
At this stage of the problem, adjust the brake for full contact with the shoes. Adjust them very tight, now back them off until you can turn the wheel by hand. Press on the brake pedal and check the adjustment again. Sometimes the obvious (loosening the shoe adjustment) is not the correct thing to do.
Agrin devil
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
Okay... I'm reading your comments...
I think calling them "oil soaked" linings is a little harsh. None of the four hubs had any noticeable oil on them... the brake shoes "feel" dry to touch. But I was able to scrape my fingernail across one and got some minor gunk that way.
When I installed and filled the new brake lines for the first time, I adjusted them just as Ray suggested.
But I have a question, since the '36 brake cylinders have TWO adjustments, how you do you know when you've got the front and rear shafts equally adjusted? Without taking all of the hubs off again?
I don't know if this is the approved method, but I adjust the front adjuster until it drags on the drum then back it off until it doesn't. Then do the rear adjuster the same way.
Ed
I still say the fault is with the linings. All the other things mentioned could cause a pull but not a lock-up.
iagree
You may, however, try riding the brakes for a while and see it the heat will take care of whatever is on or in the shoes to dissipate. Not a good solution, I know, but the alternative is new shoes.
My 41 coupe was doing the same thing. Burn out didn't work. Got new shoes from Advance Auto Parts and it fixed the problem.
BTW: You can stack a lot of stuff in that bed. Gather some of those free range chickens (not yours) and haul them to the parts store. Parts guys and gals love to eat chicken. They'll likely trade shoes for some chicken. drool Saves some money. Will too! Agrin
I go through the same thing every Spring with my '39. For two or three years they will "burn-off".....when it gets so that dosen't work I pull the right front wheel/drum and sand the linings with a real coarse sand paper. I also dress all the edges with a file. Have tried different shoes and had the same problem. The linings always look OK.
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
I just went outside to put the tractor away and lock up the shop when I saw the skidmarks. Just had to show you what I'm seeing.
dance
[Linked Image from barkerville.net]
I guess the good news is that each time I sped towards the shop, the car stopped BEFORE the door. Ha! But I'm sure my neighbors across the street are wondering "What the heck?" each time that they heard the tires squeal.
I have had to do that with my 37, ride the brakes for a little way and they always got better. Have new shoes to put on this summer, hope that helps.
Ed
That does look pretty severe. Does it release OK when you let off the brake pedal?
Ed
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
Yesterday when I let off it wouldn't release. I had to back it up a tad.
But today, as soon as I let off the pedal, it releases the brake. But the slightest pressure, locks it up again.
I had brake lock problems on my 39 sedan once. It has stainless steel sleeves and pistons in all the wheel cylinders. Turns out when i bled the brakes , all the crud in the brake fluid ended up in the bottom of the first wheel cylinder i bled.It would not allow the pistons to retract , and so locked up at the slightest touch of the brake pedal. I had to pull the pistons out and give the cylinder a good clean to fix the problem.
Is it the wheel with the longest brake line which you have bled first , that is locking up.?
JACK
Like I said, The wheel cylinder is hanging up!!!
Have you taken the wheel cylinder apart? As you probably remember there are the two boots, two pistons, two metal cups which the spring seats in presumably to protect the rubber, etc. It is easy to get one or more of these items in backwards which might cause your problem. Take the wheel cylinder apart and take a peak. Also you probably know that the dimensions of the front and rear cylinders is differenct. Make sure you have the right diameter kit for the front wheel. Jim
Re: debris in lines, Jack you make a good point restorers of vintage brakes should remember. When replacing brake parts the lines should be flushed with denatured alcohol and blow dried before connecting to the slave cylinders. It is also important to replace the rubber hoses with NEW when replacing the cylinders as that is where most moisture can enter. I would select newly made over NOS or NORS because rubber deteriorates over time.
J Franklin
Bill,
I doubt you got the wheel cylinder parts in basackards or anything like that. You would have brake fluid squirting everywhere.
You said you put new hoses on so there is little likelihood that you have an internal flap allowing fluid one way but not another (one way gate).
As to adjusting each wheel cylinder. Start off with the same amount of threads screwed in to the adjustors fron and rear of the cylinder. Adjust then by doing a little from front to rear or visa-versa. When they wheel locks down to where you can't turn it. Back off five clicks or notches. Front or rear or some of both ends. Won't matter. It is not critical that you end up with the very same length of threads. It just means that one cup and piston will be a tad farther into the cylinder, that's all.
Facing the adjuster it is clockwise to tighten. That is looking forward for the rear facing ones and rearward for the front facing ones. Of course you know that.
Good luck.
BTW: Are you sure those are not "burn out" marks? And, if as you say a lock-up problem how many times did you have to flat-spot the tire before you realized something was amiss? Agrin
I had this once...I put the springs on wrong... I did this by putting the springs on the shoe before attaching the shoe to the back plate. Thought I would save time that way. They were binding and caused lock up. Check spring location.
My black marks are on the garage floor. One time I had to drive it into the garage with the wheel locked up.
I sent you a PM...Lets talk...
Former ChatMaster
ChatMaster - 5,000
Former ChatMaster
ChatMaster - 5,000
Terrill -- haven't received a PM yet... ??
More progress today. Dick Olson came over and assisted me. We went back to basics.
1) Bled the brakes - in the order the Shop Manual recommends. LR, LF, RR, RF.
--Didn't hear or see any air. Just lots of fluid.
2) Adjusted all wheels again. Turned until tight, then backed off 5 clicks.
--Some adjustments needed 20-24 clicks before they stopped the wheel.
3) Drove car.
NOW - BOTH FRONT WHEELS LOCKED UP EACH TIME!!!!
And that DOUBLED the skid marks!!! ha ha....
Finally got my nerve up and drove the car down the block while lightly pressing the pedal. By the time I got to the end of the block (1/4 mile), the grabbing stopped.
Did this two or three times and got the brakes to work a lot smoother. Then let the car sit for an hour - drove it, and the right front grabbed AGAIN!!!! Dang it.
But the good news is that I'm now able to drive out of my driveway and down the block.
FYI -- New brake lines. New wheel cylinders. Everything is clean and "properly" installed. laugh
I think my next step is to REPLACE the brake shoes... I looked them up at TFS and I can't believe how inexpensive they are.... what the heck... that's too cheap NOT to try it.
Thanks for all of the suggestions. More later -- after I get additional nerve up to go all the way down my hill. (approx 1.5 miles - 800 feet elevation drop).
--Bill
Looks like you gotta regular "drag strip" going there... But, since I didn't hear you mention it I gotta ask...Bill...? Did you have the new shoes "arched to the drums"...? I know it is hard to get done these days...but...geez...Bill
The crud that was is the wheel cylinder on my 39 sedan was like a extremely fine silt layer, The brake tube lines were all new , the master cylinder was brass sleeved , and re sealed, and the wheel cylinders were stainless steel sleeved with stainless steel pistons. The car stopped great for a couple of years. Then duing some maintenance on the car , i bled the brakes to replace the old brake fluid, and then the wheel lock problem started.
The problem with wheel cylinders is that the inlet pipe for the brake fluid is in the centre of the cylinder. The bleed screw is placed at the top portion of the cylinder, because every knows that air in a fluid rises. So bleeding the brakes will expel the air in the lines and wheel cylinders. The fluid looks new and every thing is thought to be ok. But any of the finest particles in the brake fluid will settle to the bottom of the wheel cylinder and not be removed during the bleeding process ,because heavy particles sink, and then gets caked on hard at the bottom. The rubber cups then jamb on the crud and doesn't return to the fully retracted position.
A piece of scotch brite scourer can be used to removed the caked on particles , followed by a thorough cleaning with denatured alcohol or methylated spirits.
JACK
