Posts: 32 |
ever since my car was finished when you engaged the brakes the clutch pedal will also move and vice versa you sometimes have to pull the brake pedal up after using the clutch, any ideas as to what is causing this? I cant physically look at the linkage and springs and see a problem
-------------------- I have a 41 special deluxe 2 door town sedan
Posts: 176 |
Sounds like your return springs are in the wrong location and are interfering with the operation of the peddle returns.
Walt D 1934 Mstr 4 dr/sidemnts 1937 1/2 ton P/U 1953 Bel Air HT 1946 Aeronca 7-AC Champ
Posts: 32 |
thanks how is the best way to determine this?
Look at a picture in the parts book to see if spings are hooked up correctly....Go to Kieth Hards manual site-find 1954 parts book, then -I think its page 119 that has a good picture with springs hooked up, etc.1940-54 are basicly the same. That a great looking 1941 Black Special DeLuxe Town Sedan ![dance dance](/images/graemlins/default/dance.gif)
Posts: 32 |
thanks alot she is actually a ruby maroon just a dark pic, thanks for the advice I had someone hook the linkage up who claimed to know how but I will check out that manual
thanks
andy
This is gotta HELP ![Agrin Agrin](/images/graemlins/default/biggrinangel.gif)
