Posts: 562 Likes: 1
Posts: 562 Likes: 1 |
I've got my 36 std. steering box apart and it looks like it had a cork seal and metal retainer at the end of the pitman shaft. Has anyone come up with a modern seal to take its place? If not does anyone sell the cork seal? I don't see anything in the FS catalog. Thanks
Dick
Posts: 654 Likes: 3
Posts: 654 Likes: 3 |
Maybe an O-ring might do the job.
J Franklin
Posts: 1,294 |
Measure ID (shaft size) and OD (bore in casting). Go to your local bearing supply store and they can help you. Did that on my 52 and no leaks.
Posts: 1,381 |
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
The part number from the www.fillingstation.com is FS-72
JACK
Posts: 302 Likes: 4
Posts: 302 Likes: 4 |
An o ring works fine. Have installed an o ring on 3 steering boxes and have no leaks. Now how about sealing those spring washers on the cover assembly so the oil doesnt leak out there!
Posts: 562 Likes: 1
I went to a seal supplier and got a modern seal and pressed it in place. Will see how it holds up. Thanks
Dick
