djmahle Offline OP
I am putting a 37 4 door back together that was partially restored some 15 years ago. I need a good picture or advise of how the hood/cowl gasket or welting or whatever you call it goes on. Looks like maybe its fastened with 3 screws on each side??? Thanks for any help you cam give me.
Are you referring to the hood lacing that goes across the cowl just aft of the engine compartment? IF it's the same as my '38 the pictures below may help.
Top passenger side:
Center held by a hook with a nut under the dash:
Bottom held in the same fashion as the top:
The un-restored original:
Wow, clutch head screws. Mine has been apart for over 34 years.
My welting was basically gone. thanks for the photo.
djmahle Offline OP
Thank you very much--that is exactly what I needed.
