#274579 04/02/13 03:06 PM
Help! I accidentally hit the door latch on the drivers side of my '49 1/2 ton and it is stuck in place. Now I can't close the door. How do I release it? It is not affected by anything I do with the door handle and I can't push it back into place.
No matter where you go, there you are!
have you tried putting the handle in the open position, holding it there and while holding it, try to turn the latch to the open position?
Oreo #274584 04/02/13 03:33 PM
No, I had not done that. I just read your reply and went and tried it. It worked! Thank you so much!!!
glad it worked for you!
