Posts: 31 |
Anyone know of a front wheel hub for sale or better yet a wheel with the hub. How different is the model t hub and wheel?
1916 Chevy Service Delivery Owner 516 W 3rd Washington MO 63090 Phone 314-440-7140
Posts: 3,192 Likes: 8
Posts: 3,192 Likes: 8 |
Original chevrolet hubs for the 490 model are not easy to find. The outer thread area is very thin and does not provide much metal to support the outer bearing . The model T Ford front hubs can be used as substitute. There is a few differences , the outer threads are shorter, but the payoff is a better supported outer bearing . The outside of the model T hub has a recess just back from the hubcap, and before the wheel spokes, so they do look a bit different.(Original 490 hubs are parallel). However if you look in a 490 owners manual, the front wheel sectional view shows the recess in the hub.!! . The 490 hubcaps will fit on the T model hubs without a problem.
Your 1916 490 should have non demountable rims, and your front rims were originally 3" wide , and the rears 3 1/2 " wide. If you still have the 3" wide rims try to retain them for originality.
JACK
Posts: 2,418 |
As the wheel with nondemountable rim is only used for 1916 and partly 1917 you are searching for the "needle in the hay stack." Both to 490 and F**D, but still you can find one after a eiod of searching. The profile of the spokes to a 490 are not same as to the T-F**D. I was lucky to buy front hubs from Canada on eBay, but to get a spare wheel I had to buy a new from Calimer's Wheel Shop/USA, supplying the metal parts. http://www.calimerswheelshop.com/Try to search on eBay and elsewhere on Internet for the metal parts.
Solan G, # 32797
Posts: 1 |
I have two hubs, in fact I have a fairly complete chassis including the frame, springs, axles including the hubs. I am sure it is all original. I would like to get rid of it Cheap! Contact me if you are interested and I can send pictures.
Posts: 2,418 |
Do you have any idea of the year model? Is it a roadster or touring type? If you can post some pictures here it will help all of us.
Solan G, # 32797
