Posts: 258 |
Does anyone know are Klaxon horns are isolated from grounding out on car body? Thank you....JIM
Yes, the Klaxon 8C is isolated from it's mount. That allows you to use the two terminals as your choice. Remember, one leg of the horn wire is ground that finishes the connection at the horn button. This characteristic is common to all Chevrolet horns.
Posts: 258 |
Thanks for the response Ray: What I need to know is what is used to isolate and where is it located? JIM
Take a look at the terminals on the horn. The bolt is mounted in an insulated hole. Both sides are mounted that way so either bolt can be used for the in/out. Polarity is not a concern.
Posts: 258 |
Thank You...I will look....JIM
Posts: 258 |
Hi Ray: I think the problem is there is a set of "points" (like a distributor) that remain closed. When opening the "points" by hand, the "short" that sounds the horn as soon as it is powered up goes away. Opinion? Thanks.....JIM
You are talking about the horn adjustment. That is completely a new subject. It has been approached several times here on the Forum. Try some searches and you should locate one of them. Of course the Owner's Manual and Service Manual covers the subject in depth.
Posts: 977 Likes: 7
Posts: 977 Likes: 7 |
Bill Masters
Posts: 258 |
Hi Bill: The Manual sure does help; I have the #26 horn set. The horns work loud. The problem is as soon as the power wire touches the terminal (with no ground wire) the horn sounds. I saw in the manual they use friction tape on the horn mount bracket. This might be the problen, grounding through horn body. Will the manual print via computer? Thank you...JIM
Posts: 1,919 |
Hi Jim,
Well...you only have one terminal on your horns if you have the correct ones. You need to ground through the horn bracket. Otherwise they will not work correctly. Did you order the correct wiring harness that I told you about from RI wire? Do you have the replay installed?
What Ray told you is as if you are using a 33 or earlier style of horn.
Just for my education does the '34 and up use a horn relay? If so the horn button may be wired the same as before (making the ground when button is pushed)? The would activate the relay and let current flow to the horn which is grounded through the bracket?
The production single orn does not use use a relay. The dual horn set-up uses a relay.
Posts: 1,919 |
I agree with Chevgene....if you look in the parts book 34 is the first year a horn relay is listed. The relay is only used when the dual horns are installed.
If you can't tell this is a subject which I'm very passionate about. At Flint I was 1 of 2 '34's that had the horns installed correctly and I was going to be marked down. They were judging car to car....not to the point’s sheet. Every car in my class that had dual horns should have been marked down but 2, as they were all wrong. Also if your using a Y&Z wiring it is made up for a 33 and how the horns work in 33.
