I have a 1932 w-1 which is missing the throttle connecting rod prt no. 115-17 . I also have a 1933 w-1 for parts with the rod. The 1933 part is a different number 115-19 . How much difference is there between the rods. Is it enough that i can't used the rod in the 1932 carb.
Thanks.
JACK
You can use the 115-19 throttle rod on the 1932 carburetor.
Thank you, that is what i was hoping.
JACK
