Posts: 258 |
Sun visor mount @ driver side "A" pillar. Does someone know if the visor bracket is secured with wood screws, machine, or sheet metal screws? The new head liner is in place and the mountig holes were marked by the upholsterer. When probing this area with a small pick, all I can feel is metal. Thank you...JIM
Posts: 3,163 |
Jim The little pockets show 7x3/4 oval head chrome. It only give a part number for the actual mounting. I believe its machine screw Joe
Posts: 258 |
Thank you Joe, I just hqve to find the holes. JIM
Posts: 1,869 |
My headliner isnt in. I'll try to take a photo of the mounting location and some measurements.
Posts: 258 |
Posts: 258 |
Hi Pat: The correct screw for the metal is 8x32x1" oval head for slot screwdriver. Thank you for the effort...JIM
Posts: 1,869 |
Posts: 258 |
Hi Pat: Yes I did find the holes; once I found the first hole, I lined the plate up and the second was there. Thank you for the help...JIM
