#273556 03/20/13 03:58 PM
36dlc Offline OP
My 1928 Chevrolet project car did not come with a key but luckily it was in the unlocked position. Has anyone had luck in getting a key made for a lock like this?
On the underside of the steering lock mechanism there are 5 numbers stamped in the metal. They are 2-10-14-16-23. Do these numbers have anything to do with the key cut?
Dave Cufr #12505
1927 Capitol coupe
1928 National 4-door
1928 Speedster
1936 Standard Town Sedan
1975 Nova Custom Hatchback
the key code is on the key cylinder, pull it and any locksmith can cut you a new key if they have that year blank available, a large locksmith company will have them in stock. you probably have them, usually 5 number cuts.
Hi, The 28 poses a bit of a problem. It is necessary to remove the steering lock assembly from the column in order to get to the cylinder lock. Once you have identified the pin that retains the cylinder you have to figure out how to remove it. Not an easy chore. Generally requires drilling, and it is critical that you don't drill too deep and into the lock cylinder. Once you have removed the cylinder, make contact with Jarvis Erickson (Listed in the G&D in the Services Section.) There are two types of keys for the 28 lock. One is the single sided and the other is the double sided key. Jarvis can help with both kinds. He will need the number on the side of the LOCK CYLINDER.
Agrin devil
36dlc Offline OP
I have the steering lock assembly removed. Is the "pin" you are referring to at about the 4 o'clock position on the assembly relative to the ignition lever? If I were to drill the approximate thickness of the assembly wall should I be able to pull the cylinder out? I have another '28 with a double sided key and it fits into this cylinder so I assume it will be the double sided key that is needed.
Dave Cufr #12505
1927 Capitol coupe
1928 Speedster
M
Mychevrolets
Unregistered
Mychevrolets
Unregistered
M
Hello, I have the same issue no keys but unlocked. I tried to remove lock assembly but I did not want to force lock off column. I can slide it downward about 3/4 " then stops. I think there is a column lock in stopping my progress. Any advice would be sincerely appreciated, L.F.
36dlc Offline OP
I just returned from a locksmith in Toledo Ohio with a key for the ignition on my 1928 Chevrolet project car which did not have a key. I took it in yesterday afternoon and got a phone call about 2 hours later saying they have a key for me. When I asked how they did it they told me they got out their ring of all the 1928 Chevrolet double sided keys and started trying each key until they found the one that fit and then cut a key for me. The cost of the service is based on which end of the ring your particular key is located. I lucked out! The bill for mine was $25.
I am now a happy camper until I hit another hurdle on the "28 project.
Dave Cufr #12505
1927 Capitol coupe
1928 Speedster
GR8. You can't beat that price with a stick considering the problems you were facing to remove that lock. Wish I could find a locksmith here with all those keys so they could try it in my Coupe. Maybe I'll have to shop around. Now you can get on to your other restoration duties and wait for the next surprise. I find surprises in my Coupe and it was restored when I bought it.
I had a locksmith make keys for a door lock for one of my other old cars a couple of years ago. This guy just picked the lock and used that information to make a key. I think he only charged me $20 and he spent quite a bit of time doing it. I was impressed.
