Posts: 108 |
Need help again !!!! I'm reworking an aftermarket motorala radio for my master deluxe --but what I really need is this --the antenna is a side cowl mounted item with the btm. part a pc of hard plastic cut in half,shaped like a teardrop, black in color . What I'm looking for is a material to make a "gasket" to take up the curvature of the cowl vs. the curvature of the "teardrop" .Is there a material and how do you work it to form the gasket,was thinking of a pc. of rubber but I'm not that good with an exacto knife ---any suggestions ???
john
The original antenna had two stanchions to attach rod to cowl side....you have only one???
Posts: 108 |
Gene--remember this is an aftermarket radio, the btm. pc. is (I believe called "bakealite" )4 inches top to btm. and 1 3/4 inches left to right ,shaped like a teardrop,with two holes drilled into the cowl- a 1/4 " hole then above it a 1/2 " hole they appear to have been a do it yourself project .I'm looking for some mat'l to make a "gasket" to take up the diferent curvature (both are pretty close to each other but not the same )
john
Go to your local glass shop that installs window glass in automobiles. Ask for a few inches of his glass setting tape. If you are very careful you can mount the antenna and then very carefully trim the excess.
John, If you want some glass setting tape let me know and I will mail you a chunk-it will be easy to work with.
Posts: 108 |
Ray and Chevgene-------Thank you both for your help-as the car is in a restoration shop I stopped there yesterday (to make my monthly tribute !!)and hit on the owner for a pc. of the tape --------------WORK'S GREAT !!!! again thank's !!
john
