KMT Offline OP
1st. In the 1932 cars was there a metal plate that was a semi-half circle that the accelerator foot rest attached to, or was it bolted directly to the floor board? I saw a couple for sale on ebay and wasn't sure. In the Master Parts 29-32 book I could not find a listing for it, just one for the accelerator foot rest.
2nd. For the toe board the book lists an upper and lower toe board plate. Are these the two metal plates that surrounds the steering column? Do these then attach to the steering column grommet? Thank You.
Kent.
The semi-half circle plate was used in 1929 and 1930. For 1932 the accelerator foot rest plate is rectangular in shape with rounded corners on the upper left and on the upper right of the plate.
The upper and lower toe board plates were used around the steering column.
KMT Offline OP
I have a couple more parts to add to my shopping list.
Thank you for your help.
Kent.
