#272386 03/04/13 11:28 PM
james_h Offline OP
Does anyone have the exact position of where the running board stainless side molding is placed? Are there measurements? Thank You...JIM
Look up members in your area that have your car. I would make a trip over and check out their car. Good luck.
There should be holes in the front fender, running board & rear fender...Joe
1931 Sedan Delivery 31570
1968 Z/28 Camaro
1969 SS 396 Camaro
search the internet or examine original sales briochures for the pictures of the cars and go from there.
Does it really matter if your off by 1/2" ??? who is going to tell you your wrong.?????
mike auto
james_h Offline OP
Hi Joe: The molding clip holes were all there; I just centered both sides to the clip holes. We have a brand new set of moldings, The Filling Station clips did not fit the old or new moldings; too wide. JIM
james_h Offline OP
Hi Mike: There are no VCCA members that I know of in Montana. This 34 is the only one registered in Montana, Wyoming, the Dakotas and Idaho. What I did was center the moldings on the molding holes. Worked great; both sides measure the same distance from ft./rear fenders. Thank you for trying to help...JIM
Jim, look ast the picture of mine in the Member's Projects. Those are FS moldings.
The original 1934 running board mouldings came in a right and a left. The front of the moulding tapered up to a point in the front and was copped off almost square in the rear. The 1935 and 1936 had tapered ends at both the front and the rear. The 1937-1938 came to an equal point at the front and rear. Chevrolet sold that version for replacement on 1934-1936 cars after 1937.
james_h Offline OP
We have moldings from Northfield Forming and are correct to the original. Thanks for all you guys help.....JIM
