#271796 02/26/13 05:06 PM
1922c Offline OP
Pulling from a stop sign, heard a snap, then nothing . Pulled both axels they were ok. U joint ok Must be drive line
Is there a easy to pull the drive shaft from 1929 coach??
1922c #271811 02/26/13 07:17 PM
Is is not an easy job. Check your 1929 shop manual for instructions on how to do it.
1922c #271880 02/27/13 11:50 AM
I just helped a fellow member with the same problem on his Imperial Landau. Took some time to get things right. The depth of the shaft coming out of the pinion gear was critical since the carrier has to clear it. In his instance the carrier case was from two different cars and from the way it looked half of it was from a much earlier differential. Somewhere between 25 and 29. We put it up in the air on jack stands pulled the axles, u-joint housing, the carrier, and finally the shaft. A machine shop busted the better gear so had to match a lesser quality of gear.
1922c #271933 02/27/13 11:28 PM
1922c Offline OP
Finally got it out..was quite a job..broke at the drive gear. Looking for a shaft or repair.
1922c #271943 02/28/13 10:45 AM
New propeller shaft (aka drive shaft) is available from Billy Possum.
Look here or copy this to browser (you may need to correct the CM to .com) http://www.billypossum.com/C&P_Catalog/C&P_Catalog_rev_031225.htm
1922c #271944 02/28/13 10:48 AM
I have a (used ) 1929 Drive shaft. E-mail me if you still need one. bwbugay@aol.com
